8 years agoProblem with 128Bits from RTL module and Opencl
I have an output from RTL module with 128 bits width and I want to transfert this output to global memory for print in linux terminal. So, I know the type of 64 bits is unsigned long and What's th...
8 years agoI tried vector as you see (ulong2) but unfortunately doesn't work. I want to know exactly how to manage an output oven then 64 bit. If you know please give an example .
thank you.
