8 years agoProblem with 128Bits from RTL module and Opencl
I have an output from RTL module with 128 bits width and I want to transfert this output to global memory for print in linux terminal. So, I know the type of 64 bits is unsigned long and What's th...
8 years agoI think the vector should work I thought, at least from one of my own experiments. I forget the bit order that it is in. You might be able to write two 64 bits out and have it received by the vector type, it's been a while since I've built RTL so I'll need a bit more catchup.
