12 years ago --- Quote Start ---
library ieee;
use ieee.std_logic_1164.all;
entity MAC is
port(
rst : in std_logic;
clk : in std_logic;
M : in std_logic;
A : in integer range 0 to 2**8-1;
B : in integer range 0 to 2**8-1;
s : out integer range 0 to 2**8-1
end entity MAC;
architecture rtl of MAC is
signal A_reg: integer range 0 to 2**8-1;
signal B_reg: integer range 0 to 2**8-1;
signal AB: integer range 0 to 2**8-1;
signal old_S: integer range 0 to 2**8-1;
begin
mycore: process(rst,clk)
begin
if rst = '1' then
s <= '0'; -- ***** but s is integer? don't know what to do
elsif rising_edge(clk) then
if M = '1' then
A_reg <= 0 ;
B_reg <= 0;
AB_reg <= 0;
old_S <= 0;
else
A_reg <= A;
B_reg <= B;
end if;
AB <= A_reg * B_reg ;
old_s <= old_s_reg + AB_reg;
s <= old_s;
end if;
end process;
end architecture rtl; and know ? can you help more --- Quote End --- really impressive for a beginner.It looks ok to me. 1) you need to assign 0 and not '0' to S at reset. Moreover you better reset all nodes inside process like S otherwise you get latches. 2) you can insert the * and + assignments inside the mux else...as well but it should do 3) your last challenge is to truncate final result into S within the range 0f 8 bits. your current code means S may overflow as it will accumulate several values of A*B. I am sure you can do that. The easiest way is to convert it to std_logic_vector and chop off some bits and convert it back to integer. It will be an exercise of type conversion experience.
