12 years ago --- Quote Start --- tomorrow I will put the code may you check it and correct it ??? --- Quote End --- plenty of correct code but see my notes below:
library ieee;
use ieee.std_logic_114.all;
typing error, should be
use ieee.std_logic_1164.all;
entity MAC is
port(
rst, clk: in std_logic;
A, B : in integer range 0 to 2**8-1;
M : in std_logic;
s : out integer range 0 to 2**8-1);
end entity MAC;
ok but I prefer this below for readability:
entity MAC is
port(
rst : in std_logic;
clk : in std_logic;
M : in std_logic;
A : in integer range 0 to 2**8-1;
end entity;
-- no need to repeat library statements
--library ieee;
--use ieee.std_logic_114.all;
architecture rtl of MAC is
signal A_reg: integer range 0 to 2**8-1;
signal B_reg: integer range 0 to 2**8-1;
signal AB: integer range 0 to 2**8-1;
signal old_S: integer range 0 to 2**8-1;
signal AB_reg: integer range 0 to 2**8-1;
signal old_S_reg: integer range 0 to 2**8-1;
begin
mycore: process(rst,clk)
begin
if rst = '1' then
s <= '0'; -- ***** but s is integer?
elsif rising_edge(clk) then
if M = '1' then
A_reg <= 0 ;
B_reg <= 0;
AB_reg <= 0;
old_S_reg <= 0;
else
A_reg <= A;
B_reg <= B;
AB_reg <= AB; -- you don't need this extra register
old_s_reg <= old_s; -- you don't need this extra register
end if;
AB <= A_reg + B_reg ; -- wrong, you have added before multiplication
old_s <= old_s_reg * AB_reg; -- wrong, should multiply A_reg * B_reg then accumulate result
s <= old_s;
end if;
end process;
end architecture rtl;
