CBehr
7 years agoProblem using set_min_delay between Quartus and Timequest. Results between the two tools are inconsistent.
I'm using a test design to examine why my set_max/min_delay constraints are not working. It appears that Quartus uses the set_min_delay constraint incorrectly during compile. Setup: The design has ...
KhaiChein_Y_Intel
7 years agoFor Input/output port, you have to use set_input_delay / set_output_delay. Can you try?
