CBehr
7 years agoProblem using set_min_delay between Quartus and Timequest. Results between the two tools are inconsistent.
I'm using a test design to examine why my set_max/min_delay constraints are not working. It appears that Quartus uses the set_min_delay constraint incorrectly during compile. Setup: The design has ...
CBehr
7 years agoAddendum:
I played with the set_min_delay value on the full project and these were the results. It looks a lot like the min_delay drives the tool to generate a data path ~twice that value (but not quite).
min_delay data path clk path
9 18.7-21.7 2.3
8 16.6-19.4 2.3
7 14.1-16.8 2.3
6 11.4-14.6 2.3
5 9.4-12.4 2.3
4 6.6-9.3 2.3
Thanks in advance.
