11 years agoThanks very much for your reply Joe.
I found my problem was due to choosing VHDL for the output EDA netlist setting in Quartus Nativelink set up. When I set to Verilog HDL it all works fine. At least it simulates. Now I have to make it work. I only just started looking at transceivers and it is the first time I have used the MegaCores. I wasn't sure if the problems I was having were due to my design or with the tools. I will have a look through your archive and learn from your hard work. Thanks again. Phil
