--- Quote Start ---
This isnt all of the code..
--- Quote End ---
OK, here you go... this is the code of interest:
module proc_enhanced (Clock, DIN, Resetn, Run, Done, ADDR, DOUT, W);
input DIN;
input Resetn, Clock, Run;
output reg Done;
output ADDR;
output DOUT;
output W;
// FSM variables
parameter T0 = 3'b000, T1 = 3'b001, T2 = 3'b010, T3 = 3'b011, T4 = 3'b100;
reg Tstep_Q, Tstep_D;
// Instructions
parameter mv = 3'b000, mvi = 3'b001, add = 3'b010, sub = 3'b011,
ld = 3'b100, st = 3'b101, mvnz = 3'b110;
// Registers and Wires
wire BusWires;
wire I;
wire IR;
wire R0, R1, R2, R3, R4, R5, R6, R7;
wire A, G;
reg IRin;
reg Rin;
reg Rout;
reg Ain;
reg Gin;
reg Gout;
reg DINout;
reg AddSub;
wire Xreg, Yreg;
wire adr_subr_out;
reg incr_PC /* synthesis keep */;
reg ADDRin;
reg DOUTin;
reg W_D;
// Registers
regn reg_IR (DIN, IRin, Clock, IR);
regn reg_0 (BusWires, Rin, Clock, R0);
regn reg_1 (BusWires, Rin, Clock, R1);
regn reg_2 (BusWires, Rin, Clock, R2);
regn reg_3 (BusWires, Rin, Clock, R3);
regn reg_4 (BusWires, Rin, Clock, R4);
regn reg_5 (BusWires, Rin, Clock, R5);
regn reg_6 (BusWires, Rin, Clock, R6);
// regn reg_7 (BusWires, Rin, Clock, R7); This is replaced with the Program Counter (PC).
regn reg_A (BusWires, Ain, Clock, A);
regn reg_G (adr_subr_out, Gin, Clock, G);
regn reg_ADDR (BusWires, ADDRin, Clock, ADDR);
regn reg_DOUT (BusWires, DOUTin, Clock, DOUT);
regn reg_W (W_D, 1'b1, Clock, W);
defparam reg_W.n = 1;
// Program Counter
counter PC (Clock, Resetn, Rin, incr_PC, BusWires, R7);
assign I = IR;
dec3to8 decX (IR, 1'b1, Xreg);
dec3to8 decY (IR, 1'b1, Yreg);
// FSM State Table
always @ (Tstep_Q, Run, Done) begin
case (Tstep_Q)
T0:
if(!Run) Tstep_D = T0;
else Tstep_D = T1;
T1:
Tstep_D = T2;
T2:
if(Done) Tstep_D = T0;
else Tstep_D = T3;
T3:
Tstep_D = T4;
T4:
Tstep_D = T0;
default: Tstep_D = 3'bxxx;
endcase
end
// FSM Flip-Flops
always @ (posedge Clock, negedge Resetn)
begin
if (~Resetn)
Tstep_Q = T0;
else
Tstep_Q = Tstep_D;
end
// FSM outputs
always @(Tstep_Q or I or Xreg or Yreg)
begin
// initial values
IRin = 1'b0;
Rin = 8'b0;
Rout = 8'b0;
Gin = 1'b0;
Gout = 1'b0;
Ain = 1'b0;
DINout = 1'b0;
AddSub = 1'b0;
Done = 1'b0;
incr_PC = 1'b0;
ADDRin = 1'b0;
DOUTin = 1'b0;
W_D = 1'b0;
case(Tstep_Q)
T0:
begin
Rout = 1'b1; // Program Counter
ADDRin = 1'b1;
end
T1:
begin
IRin = 1'b1;
incr_PC = 1'b1;
end
T2:
case(I)
mv:
begin
Rin = Xreg;
Rout = Yreg;
Done = 1'b1;
end
mvi:
begin
DINout = 1'b1;
Rin = Xreg;
Done = 1'b1;
end
add, sub:
begin
Rout = Xreg;
Ain = 1'b1;
end
ld:
begin
Rout = Yreg;
ADDRin = 1'b1;
end
st:
begin
Rout = Xreg;
DOUTin = 1'b1;
end
mvnz:
begin
if (&G != 1'b0) begin
Rout = Yreg;
Rin = Xreg;
Done = 1'b1;
end
end
endcase
T3:
case(I)
add:
begin
Rout = Yreg;
Gin = 1'b1;
end
sub:
begin
Rout = Yreg;
Gin = 1'b1;
AddSub = 1'b1;
end
ld:
begin
DINout = 1'b1;
Rin = Xreg;
Done = 1'b1;
end
st:
begin
Rout = Yreg;
ADDRin = 1'b1;
W_D = 1'b1;
Done = 1'b1;
end
endcase
T4:
case(I)
add, sub:
begin
Gout = 1'b1;
Rin = Xreg;
Done = 1'b1;
end
endcase
endcase
end
// Adder/Substractor
assign adr_subr_out = (AddSub == 0) ? (A + BusWires) : (A - BusWires);
// Multiplexer
wire MUXsel;
assign MUXsel = Rout;
assign MUXsel = Gout;
assign MUXsel = DINout;
mulpxr bus_multiplexer (MUXsel, DIN, G, R0, R1, R2, R3, R4, R5, R6, R7, BusWires);
endmodule
module mulpxr (sel, DIN, G, R0, R1, R2, R3, R4, R5, R6, R7, BusWires);
input sel;
input DIN, G, R0, R1, R2, R3, R4, R5, R6, R7;
output reg BusWires;
always @ (*)
begin
case (sel)
10'b0000000001: BusWires = DIN;
10'b0000000010: BusWires = G;
10'b0000000100: BusWires = R0;
10'b0000001000: BusWires = R1;
10'b0000010000: BusWires = R2;
10'b0000100000: BusWires = R3;
10'b0001000000: BusWires = R4;
10'b0010000000: BusWires = R5;
10'b0100000000: BusWires = R6;
10'b1000000000: BusWires = R7;
default: BusWires = 9'bxxxxxxxxx;
endcase
end
endmodule
module regn (R, Rin, clock, Q);
parameter n = 9;
input R;
input Rin, clock;
output reg Q;
always @(posedge clock)
if (Rin)
Q <= R;
endmodule
module dec3to8 (W, En, Y);
input W;
input En;
output reg Y;
always @(W or En)
begin
if (En == 1)
case (W)
3'b000: Y = 8'b00000001;
3'b001: Y = 8'b00000010;
3'b010: Y = 8'b00000100;
3'b011: Y = 8'b00001000;
3'b100: Y = 8'b00010000;
3'b101: Y = 8'b00100000;
3'b110: Y = 8'b01000000;
3'b111: Y = 8'b10000000;
endcase
else
Y = 8'b00000000;
end
endmodule
module counter (clk, reset, load, en, D, Q);
input clk, reset, load, en;
input D;
output reg Q;
always @ (posedge clk)
begin
if (~reset) Q = 9'b0;
if (load) Q = D;
if (en) Q = Q + 9'b1;
end
endmodule
