CHatz's avatar
CHatz
7 years ago
Problem running ModelSim Intel FPGA Edition.
I am getting the following errors when I run Modelsim:
# ** License Issue: License request for alteramtivsim feature failed
# ** License Issue: Cannot checkout an uncounted license within a Windows Terminal Services guest session. (C:\licenses\Altera\1-N165M9_License.dat)
# ** Error: Failure to obtain a VHDL simulation license. Unable to checkout 'alteramtivsim' license feature.
I am attaching the license file:
# Intel Corporation Software and/or Intellectual Property License File
# Issued 01 November 2018
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-costash
# Primary Machine ID-NIC ID 1062E54E6255
# Companion ID-NIC ID 1062E506A13C
# Companion ID 2-N/A
# Product License Summary:
# Quartus II SE Fixed, 1 Seat(s)
# - Maintenance Expiration of 2019.11
# ModelSim - Software, 1 Seat(s)
# - Maintenance Expiration of 2017.11
# - License Expires 01-Nov-2019
# FEATURE START
# The following is a license file for the Mentor Graphics AXI3 Inline Monitor BFM
# Number of seat licenses is 1
# License Expires 01-Nov-2019
INCREMENT mgcvipae mgcld 2019.11 1-nov-2019 uncounted \
4E0D7481E84D172EA561 \
VENDOR_STRING=D9C74209 HOSTID=1062e54e6255 ISSUER=Intel SN=64550872 \
SIGN2="0121 8EAE C594 8A7C 62EB 9033 0A1C 6722 26CE DB7C 50AA 6750 \
99F8 DC04 481A 1520 FD8C 83E2 C198 81FB CF84 EB2B 94BC A419 DBBE 8B46 \
5DD0 AAAF 72D6 4872"
# FEATURE END
# FEATURE START
# The following is a license file for the Mentor Graphics AXI3 Master BFM
INCREMENT mgcvipaeaxi mgcld 2019.11 1-nov-2019 uncounted \
3E3DA4C1F7B758A2A776 \
VENDOR_STRING=2D8CE8DA HOSTID=1062e54e6255 ISSUER=Intel SN=64550873 \
SIGN2="1704 991E 3635 1DC1 F2AC 4CAB F156 B1E2 A1A1 30A4 13DE FD4C \
64D4 F937 BA27 052A 0B67 10F0 FC8F 2805 E49A 2570 8ABE D20C 8904 1F07 \
F4B9 C502 6790 C908"
# FEATURE END
# FEATURE START
# The following is a license file for the Mentor Graphics AXI3 Slave BFM
3E3DA4C1F7B758A7A771 \
VENDOR_STRING=2D8CE8DA HOSTID=1062e54e6255 ISSUER=Intel SN=64550874 \
SIGN2="16D8 DFF7 596E 8FEF 660C 4A88 D5B5 9EE4 3C91 018C 10C1 726C \
C750 00F7 7E78 13B2 6CFE B116 98D7 CFA6 F529 C3C5 7B0D 1295 4A5A D6B1 \
A7DB 75D1 151D B50C"
# FEATURE END
# FEATURE START
# The following is a license file for the Mentor Graphics AXI4
INCREMENT mgcvipaeaxi4 mgcld 2019.11 1-nov-2019 uncounted \
EE7D54F124B8BB1A4F14 \
VENDOR_STRING=D8E1B091 HOSTID=1062e54e6255 ISSUER=Intel SN=64550875 \
SIGN2="12E8 3545 80EF CFE8 8C79 C583 F9A9 3311 4C18 0532 9EDF 83D0 \
2E67 E04F 3FD5 1BAD 2DA8 06B2 E4E4 DDC2 25F8 2EBB D847 CC60 3C13 D2CE \
C90D 5E93 2E6C BE3A"
# FEATURE END
# FEATURE START
# The following is a license file for the IP Base Suite Package part number for IP
# Base Suite (NCO, FFT, FIR Compiler II)
# No license expiration date
PACKAGE ip_base alterad COMPONENTS="6AF7_00D8 6AF7_0014 6AF7_0034" \
OPTIONS=SUITE SIGN="153B EB57 5B09 B585 D1D5 3EA8 1CC3 CB52 \
DC01 2214 9CDA 4A26 598F 76C2 C126 00FE 5122 A135 BCB7 9D0A \
2BAD 5F03 BE38 FE97 EDF8 5B2A 55F2 99E3 1468 72B8"
INCREMENT ip_base alterad 2019.11 permanent uncounted 11BAD0217C16 \
VENDOR_STRING="iiiiiiiihdLkhIIIIIIIIUPDuiaaaaaaaa11X38DDDDDDDDpjz5cddddddddtmGzGJJJJJJJJbqIh0uuuuuuuugYYWiVVVVVVVVbp0FVHHHHHHHHBUEakffffffffD2FFRkkkkkkkkWL$84" \
HOSTID="1062e54e6255 1062e506a13c" TS_OK SIGN="001D 6A46 A9E1 \
B0D0 89C6 092F EEC8 E343 7623 24FD CCEA 009C 7BB1 9C10 4259 \
0699 D3C3 CC08 5B9D CA87 8978 3472 B69A B29A 0E2D A581 F5B2 \
18A8 7937 3E8E"
# FEATURE END
# FEATURE START
# The following is a license file for MAX+PLUS II Verilog
FEATURE maxplus2verilog alterad 2019.11 permanent uncounted \
E4DF65C453AC HOSTID="1062e54e6255 1062e506a13c" SIGN="0137 \
9CEE 2174 FA13 6A02 F53A 9186 4E41 BEA6 210E 6D48 E345 C4A0 \
FB1E 6AE9 0346 562D 82F6 BF8B 051D F32B 7445 A677 B5ED CF9A \
720A 01F8 DD19 613A 1992"
# FEATURE END
# FEATURE START
# The following is a license file for MAX+PLUS II VHDL
FEATURE maxplus2vhdl alterad 2019.11 permanent uncounted 592D637D59AA \
HOSTID="1062e54e6255 1062e506a13c" SIGN="040E 97EE 56F3 789F \
53C5 FFEF DE08 CBE1 4314 F47B 16BD 84BD E18C 91A0 5D17 18E3 \
A510 6CF6 A615 81DC 6E02 78F9 05C8 5A4E B862 083B EA03 401D \
5427 DDDF"
# FEATURE END
# FEATURE START
# The following is a license file for the Intel Design Security feature for the Quartus
# II Software.
FEATURE quartus_nonvolatile_encryption alterad 2019.11 permanent \
uncounted 7CA30EA65694 HOSTID="1062e54e6255 1062e506a13c" \
TS_OK SIGN="102F 4919 A052 720A 7286 C0F6 E250 58BD 4331 58AE \
1D2E 9DB2 C8A5 4BD0 E78C 1EBE 6877 5E5C 8C17 42AE 9A05 550F \
93C5 2306 9D1E 3F9F B3B4 66D7 D889 A5AB"
# FEATURE END
# FEATURE START
# The following is a license file for the ModelSim
INCREMENT alteramtivsim mgcld 2019.11 1-nov-2019 uncounted \
FE6D34514683DD9E928B \
VENDOR_STRING=2EF72658 HOSTID=1062e54e6255 ISSUER=Intel SN=64551345 \
SIGN2="0446 60F8 7578 0637 B52A 1453 0684 6950 F306 529E 96AF F8A5 \
78D8 7892 5287 031F 924A F8C8 43F8 8CE1 A0B9 C690 15EB 41A4 DF4F 2FB9 \
61B0 3AA2 4BE0 B18A"
# FEATURE END
# FEATURE START
# The following is a license file for the Altera Quartus II Subscription Edition Fixed
FEATURE maxplus2 alterad 2019.11 permanent uncounted 231CDB5655B5 \
HOSTID="1062e54e6255 1062e506a13c" SIGN="13A3 89BA 52B7 D23E \
41D7 9006 4D45 8A8C A170 6C29 61A4 5F68 565B DA47 446F 0ADF \
9CB2 4F94 FABD 544A AD3B F304 7F6C 2F59 16C0 6DDD 0DFC F92A \
FEFF 5B4D"
FEATURE quartus alterad 2019.11 permanent uncounted 88EB11CCB3E5 \
HOSTID="1062e54e6255 1062e506a13c" TS_OK SIGN="02E3 2F4A A169 \
6854 77AB 97ED 5403 0DCA 3682 F602 9E95 A104 D2E7 2EDC 764B \
1E19 9A5D 725E F520 94AF F18F 46B8 6672 AB8B 1815 D527 B701 \
9960 83A0 39B3"
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 11/01/2018
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello Welcome to INTEL forum. Referring to error message (License Issue: Cannot checkout an uncounted license within a Windows Terminal Services guest session) looks like you are using remote session. From my understanding, if you are accessing a machine over a remote desktop session, you need a Floating style license. You can contact our nearest Intel sales person or distributor about converting existing Fixed locked licensing or obtaining new floating licenses. https://www.intel.com/content/www/us/en/programmable/buy/intellectual-property.htm Our sale and distributor team shall review and respond to your request.
  • hans86's avatar
    hans86
    Hi CHatz,
    Yes as AAbd mentioned remote desktop is blocked for Windows RDP if you are using a mobile compute license. However the good news is that any other remote desktop tool such as TightVNC, logmein, teamviewer etc all work fine.
    Good luck,
    hans86
    PS publishing your license is not a good idea, it is fairly easy for somebody to spoof your MAC address.
