Altera_ForumHonored Contributor16 years agoproblem of setting max_fanout Below is the critical path of my design. As you can see, several cells has big fanout, so the IC delay is big. I want to constrain max_fanout to 10 to reduce IC delay. But how to set it? I tried to s...Show More
Altera_ForumHonored Contributor16 years agoThank you very much for this explanation. I am new to FPGA design. thanks a lot!
Recent Discussionsagilex7 ram back-annotationFIR IP configured for InterpolationSSLC Login Issue – "You need to enroll" loop after OTP verificationA5EG013BB18A OPN is visible in Quartus but not listed in Program File Generatoraltera scfifo ip with power-up initial value
