9 years agoProblem in using the same module in project for many times
Hi everyone, I am trying to use one module for several times in one project cause I want to control several ADCs using one main project. And my way to do it is like this:
ADC ADC1(.RS...
9 years agoYour naming is a little confusing! So DOUT1 and 2 are *inputs* to the FPGA and DIN and SCLK are *outputs* from the FPGA. DOUT1 and 2, if they are driving clock inputs, should be set up as base clocks with the create_clock command.
