9 years agoProblem in using the same module in project for many times
Hi everyone, I am trying to use one module for several times in one project cause I want to control several ADCs using one main project. And my way to do it is like this:
ADC ADC1(.RS...
9 years agoSorry, I did not explain my problems clearly. So, DOUT1 & DOUT2 are outputs of two ADCs. They are used to trigger my microcontroller to read the output. I think that is why quartus treats DOUT as a clock, and SCLK is the clock I sent to ADC(not a real clock, only when DOUT is vivid, SCLK equal to CLK; or SCLK is 0). DIN is to set the configuration registers in the ADC.
I have run a clocks report in timequest and there is no problem except the warning I posted before. By the way, .sdc file had no problem when I was testing one ADC. I am using ADS1018 by TI.
