Problem in running Questa with Testbench
As a starting point, I recommend following the steps and example design provided in the user guide to familiarize yourself with the simulation flow:
https://docs.altera.com/r/docs/703090/21.1/questa-intel-fpga-edition-quick-start-intel-quartus-prime-standard-edition/questa-intel-fpga-edition-simulation-quick-start-intel-quartus-prime-standard-edition?contentId=Ji3cTMv3yN78urty1lwAVw
Once you have the example design running successfully, try applying the same flow to your own project. This will help verify that the simulation environment is set up correctly and make it easier to identify any project-specific issues.
Richard Tan
Hi Richard
In the above link, I couldn't open and download the file pointed below:
- Lisze1 month ago
Hi Richard,
It's ok. I manage to use Testbench with my code now. Thank you.
- RichardT_altera1 month ago
I am glad to know that it works.
Try this link whether it works for you: https://docs.altera.com/v/u/resources/747435/quartus-std-lite-pll-ram-zip-file
