Lisze
2 months agoProblem in running Questa with Testbench
I have saved the testbench within the Addern.v file (attached). I can launch Questa from Quartus. But there are no inputs and outputs in the Objects window in Questa, as shown below: Please a...
RichardT_altera
1 month agoAs a starting point, I recommend following the steps and example design provided in the user guide to familiarize yourself with the simulation flow:
https://docs.altera.com/r/docs/703090/21.1/questa-intel-fpga-edition-quick-start-intel-quartus-prime-standard-edition/questa-intel-fpga-edition-simulation-quick-start-intel-quartus-prime-standard-edition?contentId=Ji3cTMv3yN78urty1lwAVw
Once you have the example design running successfully, try applying the same flow to your own project. This will help verify that the simulation environment is set up correctly and make it easier to identify any project-specific issues.
Richard Tan
Lisze
1 month agoThanks Richard, for your recommendation. I will try.
