Engineer87
2 years agoProblem in Quartus Prime I++ HLS Compiling "The command line is too long."
hello every one. I got sticky problem in compiling my C++ code. when compiling wants to be finished the compiler stops and showing this message: The command line is too long. HLS Main Optimizer ...
- 2 years agoI finally found the solution. The answer is : compiling c++ code in fpga mode with i++ compiler needs a huge amount of Ram and hdd resource for page filing. For example a cycloneV design needs about 64gb ram and resource. it depends on your design. That is it.
Engineer87
