Problem FSM
- 3 years ago
The problem was not the triggered in the FSM. When you have a FSM and some signals are going to change in some cases, you need to initialize them at the beginning so the FSM can see signals change in every case possible.
By using the comparison trigger condition, i'm getting the signal tap waveform below (image):
May check out this video https://www.youtube.com/watch?v=WJFKBWCnAB4&t=1026s for the trigger condition details. I had sent the project file to your email.
For those red coloured signals are not in the node list due to being optimized away. But can try to preserve those signals by using keep or preserve attribute check this link https://www.intel.com/content/www/us/en/docs/programmable/683552/18-1/signal-preservation.html. However, I try with keep attribute on next_state signal but that affected the waveform result.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
