gomezramones
3 years agoProblem FSM
There is a problem that when I tried to design a FSM, the code never enters to that part. I simulated the same code in ModelSim and it was working fine.
FSM_I2C : process(current_state,next_sta...
- 3 years ago
The problem was not the triggered in the FSM. When you have a FSM and some signals are going to change in some cases, you need to initialize them at the beginning so the FSM can see signals change in every case possible.
gomezramones
3 years agoI forwarded you the project to your email
