15 years agoYou could try "touch"ing the file first...i.e.: "touch buggy.bsf" from a shell in your home directory.
Also:- Make sure that your umask settings are correct. I've always used 022. Type "umask" from a shell, by itself, to see what the value currently is. "umask 022" to change it to more common permission settings.
- There's a good description in the manpage for umask, in case you need it.
- Make sure that the permissions on /home/ricwe/buggy are correct, as well.
