12 years agoProblem compiling hello world on Windows
I am attempting to compile and run the hello world design example using the emulator on Windows 7 with Visual Studio 2013. I have AOCL and Quartus installed and the environment configured according ...
9 years ago --- Quote Start --- I copied the aocx file and the exe in the same directory, and can run the host program, but it can’t find any OpenCL devices! I think the “aocl install” command is buggy (reports success but “aocl diagnose” finds issues;-) From an Administrator command prompt: I had run "aocl uninstall" before this to start from a clean slate. But apparently the driver was not installed, despite the last message. --- Quote End --- Facing the exact same problem here. "Unable to open the kernel mode driver. Please make sure you have properly installed the driver. To install the driver, run aocl install" Any follow up or help please? Thanks
