12 years agoProblem compiling hello world on Windows
I am attempting to compile and run the hello world design example using the emulator on Windows 7 with Visual Studio 2013. I have AOCL and Quartus installed and the environment configured according ...
10 years agoI copied the aocx file and the exe in the same directory, and can run the host program, but it can’t find any OpenCL devices!
--- Quote Start --- … MMD ERROR: can't load the WinDriver library ERROR: CL_DEVICE_NOT_FOUND Location: ..\common\src\AOCLUtils\opencl.cpp:354 Query for number of devices failed --- Quote End --- I think the “aocl install” command is buggy (reports success but “aocl diagnose” finds issues;-) From an Administrator command prompt: --- Quote Start --- C:\windows\system32>aocl install aocl install: Running install from C:\altera\15.0\hld\board\s5_ref/windows64/lib exec +------------------------------------------------------+ + Installing kernel driver module... + +------------------------------------------------------+ WDREG utility v10.21. Build Aug 31 2010 14:21:54 Processing HWID *WINDRVR6 Installing a signed driver package for *WINDRVR6 LOG ok: 1, ENTER: DriverPackageInstallA LOG ok: 1, ENTER: DriverPackageInstallW LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, RETURN: DriverPackageInstallW (0xE000024B) LOG ok: 1, RETURN: DriverPackageInstallA (0xE000024B) difx_install_preinstall_inf: err e000024b, last event 0, last error 0. UNKNOWN install: completed successfully +------------------------------------------------------+ + Installing board drivers... + +------------------------------------------------------+ WDREG utility v10.21. Build Aug 31 2010 14:21:54 Processing HWID PCI\VEN_1172&DEV_D800&SUBSYS_00051172&REV_01 Installing a non-signed driver package for PCI\VEN_1172&DEV_D800&SUBSYS_00051172 &REV_01 Device node (hwid:PCI\VEN_1172&DEV_D800&SUBSYS_00051172&REV_01): does not exist and is not configured. Pre-installing. LOG ok: 1, ENTER: DriverPackagePreinstallA LOG ok: 1, ENTER: DriverPackagePreinstallW LOG ok: 1, RETURN: DriverPackagePreinstallW (0xE000022F) LOG ok: 1, RETURN: DriverPackagePreinstallA (0xE000022F) difx_install_preinstall_inf: err e000022f, last event 0, last error 0. UNKNOWN install: completed successfully --- Quote End --- I had run "aocl uninstall" before this to start from a clean slate. But apparently the driver was not installed, despite the last message. --- Quote Start --- C:\windows\system32>aocl diagnose aocl diagnose: Running diagnose from C:\altera\15.0\hld\board\s5_ref/windows64/l ibexec Unable to open the kernel mode driver. Please make sure you have properly installed the driver. To install the driver, run aocl install DIAGNOSTIC_FAILED --- Quote End ---
