13 years agoProblem! Binary Divisor: Error (10028): Can't resolve multiple constant drivers
Hi! I'm trying to make a binary divisor of 4 bits in VHDL. The process i'm using to get the quotient is to compare and substract. So, what I want to do is to subtract certain binary number wi...
13 years agoI'm done :(
According to me theres no more signals of sensitivit to add. Please help! It stil shows these errors: Error (10028): Can't resolve multiple constant drivers for net "EDO.IDLE" at DIV.vhd(50) Error (10029): Constant driver at DIV.vhd(40) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_1" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_2" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_3" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_4" at DIV.vhd(50) Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 7 errors, 20 warnings Error: Peak virtual memory: 226 megabytes Error: Processing ended: Sat Nov 03 19:18:09 2012 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 The code again: ---- entity Div is port (Dividen: unsigned(3 downto 0); Divisor: unsigned(3 downto 0); RST, CLK: in std_logic; Cociente, Residuo: out std_logic_vector(3 downto 0)); end entity Div; architecture NICE of DIV is component SumadorRestador is port( A,B: in std_logic_vector(7 downto 0); Se: std_logic; S: out std_logic_vector(7 downto 0)); end component SumadorRestador; type EDOS is (IDLE, RES_1, RES_2, RES_3, RES_4); signal EDO, EDOF: EDOS; signal A,B,C,D: unsigned(3 downto 0); signal A_1,B_1,C_1,D_1: unsigned(7 downto 0); signal Coci: std_logic_vector(3 downto 0); signal Ini: std_logic; signal Dividendo: unsigned(7 downto 0); begin Dividendo <= "0000" & Dividen; Ini <= RST; p1: process(CLK,RST) begin if RST = '0' then EDO <= IDLE; elsif CLK'event and CLK='1' then EDO <= EDOF; end if; end process; p2: process (EDO, A, B, C, D, Ini, Dividendo, Divisor) begin case EDO is when IDLE => if Ini = '0' then EDO <= RES_1; else EDO <= IDLE; end if; when RES_1 => if (A > Divisor) or A = Divisor then A_1 <= "0000" & A - Dividendo; Coci(3) <= '1'; EDO <= RES_2; else A_1 <= "0000" & A; Coci(3) <= '0'; EDO <= RES_2; end if; when RES_2 => if B > Divisor or B = Divisor then B_1 <= "0000" & B - Dividendo ; Coci(2) <= '1'; EDO <= RES_3; else B_1 <= "0000" & B; Coci(2) <= '0'; EDO <= RES_3; end if; when RES_3 => if C > Divisor or C = Divisor then C_1 <="0000" & C - Dividendo; Coci(1) <= '1'; EDO <= RES_3; else C_1 <= "0000" & C; Coci(1) <= '0'; EDO <= RES_3; end if; when RES_4 => if D > Divisor or D = Divisor then D_1 <= "0000" & D - Dividendo; Coci(0) <= '1'; EDO <= IDLE; else D_1 <= "0000" & D; Coci(0) <= '0'; EDO <= IDLE; end if; when others => null; end case; end process; p3: process (EDO) begin case EDO is when IDLE => Cociente <= Coci; when RES_1 => A <= Dividendo (6 downto 3); when RES_2 => B <= A_1(2 downto 0) & Dividendo(2); when RES_3 => C <= B_1(2 downto 0) & Dividendo(1); when RES_4 => D <= C_1(2 downto 0) & Dividendo(0); end case; end process; end architecture NICE;
