10 years ago
Problem assigning IO pin for MAX 10M08DAF484C8GES
Hi everyone,
I'm currently using Quartus Prime Lite 15.1.1 Build 189 to work on a hobby project on a BeMicroMAX10 development board that decodes a PPM signal into several PWM outputs. When I tried to test my design I ran into a problem with Quartus Prime Pin Planner.
The PPM to PWM decoder has 8 outputs, pwm_out[0..7] . When I assign the pins as following:
VREF group B5_N0
pwm_out(0) -> R15
pwm_out(1) -> P15
pwm_out(2) -> P15
VREF group B1_N0
pwm_out(3) -> D3
pwm_out(4) -> E1
pwm_out(5) -> F2
pwm_out(6) -> F1
pwm_out(7) -> G1
I ran into a strange problem. If I kept the pins' assigment as above. pwm_out(0 to 2) will not have any PWM output after the FPGA is configgured http://www.alteraforum.com/forum//images/icons/icon9.png . If I removed any one of the pins from pwm_out(3 to 7), I will be able to see my PWM signals on pwm_out(0 to 2).
I wonder if this is a problem with Quartus Prime Lite or it is a mistake I made when assigning these pins. Thanks you for your help
