13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years agoThis is the point, you're not supposed to generate a 50% duty cycle, as the "other" bit of code should also be using mclk as the clock. But it is only enabled with clk_en (hence it only works one in every N clocks)
