10 years agoProbem in a state machine code
Hi, I'm new in VHDL and I have a problem with this code: The problem is that when I program it on The FPGA, even when SW(4) is equal to 0, LEDR(0) is equal to 1. And It stays on this state even...
10 years ago --- Quote Start --- I didn't look at your code, but you should check your board documentation to see if the switches or LEDs are wired as active low rather than active high. --- Quote End --- I have already done it. They are active high.
