OldMarty
5 years agoPrime Lite 20.1.1 - Where is Megafunction wizard please?
Hi all, I've recently started using Prime Lite 20.1.1 (after using v13.x in recent years). However, when i place a megafunction device in my schematic design, i no longer see/get a prompt to us...
Nurina
5 years agoHi,
You see the "Save IP Variation" prompt because this IP is not available in your project library so this will generate the required files for this IP to work. Once you save the IP variation you will be prompted to edit the parameters of this IP on the MegaWizard. You can find the IP symbol in the "Project" library.
Nurina
