10 years agoPRESERVE_UNUSED_XCVR_CHANNEL persisting critical warning
Hello, I'm using Quartus 16.0.1 Prime and I'm using the Arria10 FPGA. (DEVICE=10AX115U4F45E3SGE3). When compiling a design without RX/TX channels I always get this critical warning: Criti...
10 years agoHi Bob,
That made it working. (it should be "set_global_assignment" and not "set_instance_assignment". Now I see in the Fitter log: Info (17952): Global preservation of unused RX channels is enabled. Preserving 72 unused RX channel location(s). Info (18653): Global preservation of unused TX channels is enabled. Preserving 72 unused TX channel location(s). Info (17953): Preserved 72 unused RX channel(s). Info (18654): Preserved 72 unused TX channel(s). So, problem solved. Thanks! Regards, Leon BTW: I'm still using Quartus 16.0.0 standard. (I cannot get the pro version to work; I get the same issue as described here: http://www.alteraforum.com/forum/showthread.php?t=52337&highlight=prime )
