12 years agoPRE_FLOW_SCRIPT_FILE problem
Hi. I am trying to write the script for automatic update compilation time in my project. The script generate_version1.tcl: set str -format {%Y%m%d%H%M}]
set hex_value ${str}
set num_digits
12 years agoThis zip file associated with this tutorial has an example that works ...
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104code_hawkins.zip Look in the folder, ESC-104Code_Hawkins\dsp_tutorial\vhdl\boards\de0_nano\cyclone4\dsp_tutorial\scripts, at the scripts synth.tcl and synth_preflow.tcl Cheers, Dave
