9 years agoPower analysis flow from OpenCL
Hi guys, I'm trying to figure out if I can carry out a power analysis on a kernel I have without firing up Quartus PowerPlay. My knowledge of Quartus and all that entails is lacking so if there...
9 years agoGo inside the folder that is generated by AOC and run "quartus_pow top.qpf". This will generate the power report in text format after a few minutes. Of course the estimation will be done with default settings since you are not supplying signal activity info.
