NilsLiang_WNC
3 years agoPostive edge detector design
I've met a unexpected behaviour with my design and I just can't figure it out why.
First, I did some logic to detect the postive edge of input signal. Then I use the pulse to drive output signal to...
RichardT_altera
3 years agoHave you try to simulate the design to check the design functionality?
Does the clock toggle correctly in the signal tap?
Sharing the full design may help to further understand the problem.
Richard Tan
