9 years agoPost Synthesis simulation fails, problem with RTL?
Hello all, I have a relatively simple state machine that works just fine for functional pre-synthesis simulation in Modelsim. However, after running Quartus synthesis and fitter and extracting the...
9 years agoYou didnt post the whole code, so I have to assume you're using a 2 process state machine style?
increment appears to not be set in all states, so a latch will be created. Latches can have timing problems in hardware - so it is recommended that you avoid them.
