10 years agopost-scale counter cascading problem in MAX 10
Hello All, I am looking or a way to cascade post scale counters of PLL in my MAX 10 device. For example , I want to drive c1 counter of PLL by using c0 as the input. Thanks in advance! ...
10 years ago --- Quote Start --- I don't believe you can do this (but I could be wrong). You can do the post scaling outside of the PLL. --- Quote End --- Thanks. May be you are right. All the documents of MAX10 or ALTPLL IP says it can be done but no detailed description attached. -Taufiq
