Do you mean that post-fit includes the timing infromation, despite of the "Functional Simulation Only" option in netlist writer?
--- Quote Start --- Do you mean that post-fit includes the timing infromation, despite of the "Functional Simulation Only" option in netlist writer? --- Quote End --- Most likely not if explicitely set. I asked, because functional simulation of post-fit netlist seems unusual to me. I only used it for timing analysis. The question is however, which difference in the netlist can change execution sequence in functional simulation?. - Altera_Forum
Have you tried doing this again without using the buffer port type? Its hardly used by anyone, and not really the standard way to create output registers. Usually you would use an internal signal to store the value and assign an output to the internal signal. Another thing I notice is that in your code you have 2 separate if statements resetting the counter. It would be more common to use something like:
if CNT= 1000 or START = '1' then CNT <= 0; else CNT <= CNT + 1; end if; - Altera_Forum
@Tricky: I don't see, why the said constructs, that are legal and well-defined VHDL code, should change the synthesis result.
Regarding negative integers, I understood a bit more when reviewing your post. The integer signal has to be converted to a numerical bit-vector during synthesis. One should expect integer range 0 to 1000 to be converted to unsigned(9 downto 0). Quartus generally accepts integer signals, also for ports, and generates correct code for it. They are even suggested in the Quartus language templates. But in the said case, Quartus converts the integer apparently to a signed signal:
That's no problem in logic synthesis, because the bit-vector is identical. But the simulator stumbles upon it. It may be necessary to change to an unsigned port signal for simulation of Quartus post-fit netlists.CNT <= IEEE.STD_LOGIC_ARITH.CONV_INTEGER(SIGNED(ww_CNT));
