Post configuration issue for Cyclone II EP2C35F484C7N
I am trying to make a post config BSDL for the Cyclone II EP2C35F4847N, but the post configure file appears “syntax error” when import to the Boundary Scan library.
When open the *_new.bsdl file it looks like the generating with Quartus II was abort. So the new BSDL is not complete. I compared with the original BSDL and found there is no define for END of the BSDL and short of from 1400~1448.
I am wondering if the BSDLCustomizerv2-4.tcl script issue or my Quartus software issue.
Could you pls help send me a correct one so that I could continue to do the Boundary Scan test?
Attached pls find the pre-config BSDL of EP2C35, pin file, tcl script for cyclone II and “syntax error” post config BSDL for your reference.
Thank you!
- Nooraini_Y_Intel
Hi SYan6,
This should be the same question that has been address in the thread below:
Nooraini
- SYan6
Hi Nooraini, Sorry for the double submit. Thank you so much for the answer! Best, Shixia
