SYan6
7 years agoPost config BSDL file (In System) for the Cyclone II issue
I am trying to make a post config BSDL file (In System) for the Cyclone II, but the appears “syntax error” when import to the Boundary Scan library.
When open the *_new.bsdl file it looks like the generating was abort. So the BSDL is not complete. I compared with the original BSDL and found there is no define for END of the BSDL.
I am wondering if the *.tcl script issue or my Quartus software issue.
Could you pls help send me a correct one so that I could continue to do the Boundary Scan test?
Thank you!
- Nooraini_Y_Intel
Hi SYan6,
I have tried using the quartus_sh v18.1 to run the BSDLCustomizerv2-4.tcl file and successfully generate the *_new.bsd file with complete pins. You can refer to the .zip file for the *_new.bsd file.
Nooraini
- SYan6
Hi, Nooraini Thank you so much for help! I will try it for boundary scan with the new *.bsd you provided. Best, Shixia
