10 years agoPorting GPU kernels to Altera boards
Hello! I am investigating porting some kernels from AMD GPU to Altera. These kernels make heavy use of OpenCL images and local memory. They require OpenCL 1.2 support. A few questions:...
10 years ago --- Quote Start --- Hi, i believe this is not the case, probably is only for the time being with out the open cl 2.0 in the road map, i believe sooner or later it may support that. maybe sooner. --- Quote End --- Thanks. Are images currently supported ?
