Mathiazhagan's avatar
Mathiazhagan
4 years ago
Porting from Xilinx to Altera
Hi there,
I want to convert a huge project which contains around 45 sub modules and around 44 ip cores of xilinx from Xilinx to intel, Is there any way to convert else i have to do it from the scratch level.
How to define a parameter outside the module of a HDL Code in altera, Please share me the format for defining a keyword parameter in HDL Code.
Thanks in Advance
  • I believe I have provided the support/answer that you needed in order to proceed with your project. With that, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
  • Mathiazhagan's avatar
    Mathiazhagan
    Dear RichardTanSY,
    I opened a new project and added the .qsf file but am not able to view the files, could u please share me the individual files that u have converted instead of a single .qsf file, I will add all the converted files to the new project created and let me check.
    With Regards,
    V.Mathiazhagan
    Mathiazhagan
    Dear Richard Tan,
    Thanks a lot, I got the required support in order to proceed further in my work, The converted code is for Agilex, Will i able to use the agilex converted code to work on a cyclone 5 series boards.
    With Regards,
    V.Mathiazhagan
