Porting from Xilinx to Altera
- 4 years ago
I believe I have provided the support/answer that you needed in order to proceed with your project. With that, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
Dear Richard Tan,
Thanks for saying that you will be converting the modules if i share u the xpr file, Is it possible to convert the complete project from xpr to qpf and can expect that it will work fine
May I compress the complete xilinx project with required support files and can i share it to you, Will u able to convert it
With Regards,
V.Mathiazhagan
Hi @Mathiazhagan
If your design contain purely RTL, there is a possibility that it will work fine but since your design contain Xilinx IP core, I have my doubt there. It may need some work after converting the design, e.g. replacing the xilinx MMCM to intel PLL.
You may checkout this document.
If the compressed xilinx project can be fully compiled again in Vivado, I think it should be good to go.
Richard Tan
