10 years agoPoor heterogeneous memory performance in Quartus 14.1
EDIT: This happens in Quartus 15.1 and 16.0 as well. Hi All I have an issue with low performance when using multiple memory systems on the DE5Net Board. When using 2 Memory Systems, the no...
10 years agoSignal tap will help. Profiler may also tell you if there's any change to the actual kernel execution time.
