10 years agoPoor heterogeneous memory performance in Quartus 14.1
EDIT: This happens in Quartus 15.1 and 16.0 as well. Hi All I have an issue with low performance when using multiple memory systems on the DE5Net Board. When using 2 Memory Systems, the no...
10 years agoHave you tried using the CL_MEM_HETEROGENEOUS_ALTERA flag? This hint tells the host runtime to allocate into the heterogeneous memory. What you may be seeing is the host copying out of default memory prior to kernel execution, and that overhead is getting lumped into the kernel execution time.
