12 years ago
Polynomial Evaluation
I'm totally new to VHDL and i'm trying to do a polynonamial evaluation. In particular I have a signed 16 bit value (x) and I want to obtain y=d*x^3+c*x^2+b*x+a.
I have created a signed multiplier:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
ENTITY my_signed_multiplier IS
PORT( in1, in2 : IN signed (15 DOWNTO 0);
clk,clr : IN std_logic;
result : OUT signed(15 DOWNTO 0));
END ENTITY my_signed_multiplier;
ARCHITECTURE logic OF my_signed_multiplier IS
SIGNAL in1_reg, in2_reg : signed (15 DOWNTO 0);
SIGNAL out_reg : signed (31 DOWNTO 0);
BEGIN
PROCESS(clk,clr)
BEGIN
IF clr ='1' THEN
in1_reg<=(OTHERS => '0');
in2_reg<=(OTHERS => '0');
out_reg<=(OTHERS => '0');
ELSIF rising_edge(clk) THEN
in1_reg<=in1;
in2_reg<=in2;
out_reg<=in1_reg*in2_reg;
END IF;
END PROCESS;
result<=out_reg(31 DOWNTO 16);
END ARCHITECTURE logic;
Now I was supposed to create another entity which has a generic variable (eg: pow : integer ) that specifies how many instance of my_signed multiplier use to obtain the correct signal power elevation. By the way now I'm stuck is I don't know exactly how to do it.
Any suggestions is appreciated . Thank you !
