10 years agoPOF file
Why an Assembler generated POF file is different than a POF file generated by "Convert Programming Files..." tool? Both files are the same size but a significant number of bytes are different. Compar...
10 years agoHi,
Google gave me this documentation of the POF format: http://www.pldtool.com/pdf/fmt_pof.pdf (http://www.pldtool.com/pdf/fmt_pof.pdf) (doesn't look like the "official" documentation, but I think it's sufficient). It's very terse, but as you can see, there's a "Creator_ID", which identifies the "program which created the POF", so that field will obviously change depending on whether the assembler tool generates it or the programming file converter tool creates it. Best regards, GooGooCluster
