Altera_ForumHonored Contributor16 years agoPLL megacore probs.build my own?? Hi all, I want to implement a PLL that will lock onto & track an incoming signal of about 30KHz and output a multiple of that locked frequency. I tried using Quartus's PLL megacore function but...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
