16 years ago --- Quote Start --- The thing with this is that even if the two XOR inputs have the same frequency, if theyre not in phase there will be a train of 1's at the XOR output. --- Quote End --- Yes, a PLL has the purpose to pull the (divided) VCO phase to the input phase. With an XOR gate, both inputs must have 50% duty cycle and it operates with 90° pahse shifz between both inputs. Other phase comparator typed are achieving 0° phase shift.
