16 years ago --- Quote Start --- The noise/jitter,therefore is not particularly specified. --- Quote End --- To mention an obvious fact. Above a certain input signal jitter, no meaningful PLL operation can be expected. A phase noise analysis of the input signal can answer the question. Generally, I hear from your answer, that a time discrete 5 MHz clock based .e.g. on a 40 or 80 MHz system clock can be acceptable. This would basically allow an all-digital PLL solution.
