13 years agoPLL is not fully compensated . . .
Hi, I have a question concerning a warning that I get when compiling my design. The warning is as follows: Warning: PLL "pll_for_fft:inst28|altpll:altpll_component|pll_for_fft_altpll:auto_...
13 years ago --- Quote Start --- Hi, I have a question concerning a warning that I get when compiling my design. The warning is as follows: Warning: PLL "pll_for_fft:inst28|altpll:altpll_component|pll_for_fft_altpll:auto_generated|pll1" input clock inclk[0] is not fully compensated and may have reduced jitter performance because it is fed by a non-dedicated input So as far as I understand the meaning of this warning, it says that the signal that is fed into the PLL (which in this case comes directly from a physical I/O pin of the FPGA) is not a dedicated clock signal. Well, in my understanding, the input pin from where that signal is routed IS a dedicated clock (input) pin. Is that so (please see attachment)? Or where can I find a dedicated clock input pin that would make this warning go away? Thanks, Maik --- Quote End --- Does your clock pin feed the PLL directly and exclusively. I mean do you use same clock for some other sections?
