16 years agoHere's the whole content of the sdc file:
# ######################################### create_clock -period 37.037 -name my_clk -add [get_ports {clk}] derive_pll_clocks # or else instead of the last line (causing the same result) # create_generated_clock -name sys_clk -source [get_ports {clk}] -multiply_by 4 [get_nets {inst2|altpll_component|_clk0}] # create_generated_clock -name sdram_clk -source [get_ports {clk}] -multiply_by 4 [get_nets {inst2|altpll_component|_clk2}] # and variations of the last line: # create_generated_clock -name sdram_clk -source [get_ports {clk}] -phase -144 [get_ports {SCLK}] # create_generated_clock -name sdram_clk -source [get_nets {inst2|altpll_component|_clk2}] [get_ports {SCLK}] # virtual clock for host interface, maybe period too small create_clock -period 1000.000 -name virt_jtag_clk [get_ports {altera_internal_jtag*}] # ######################################### # slow asynchronous I/Os # reset set_false_path -from [get_ports {/GDCRST}] # jtag set_false_path -from [get_ports {altera_internal_jtag*}] set_false_path -to [get_ports {altera_internal_jtag*}] # ######################################### The project and the report unconstrained paths result is shown in the pdf. Just that one single added output port seems to cause the strange behaviour?!?
