15 years ago
PLL input from non-dedicated clock pin
Hello all,
I've struck with a simple problem and I'm almost nearing the wall in terms of options.
I've a design in which the clock is coming from a non-dedicated clock pin (PIN_AJ16). I've to generate a divide-by-2 clock and I read in the forum the best way is to use PLL.
PLL can be driven from Global clock lines or dedicated clock pins. So, I instantiated a ALTCLKCTRL megafunction to route the pin on global clock line and then use that as input for the PLL. But, I still get the same error
Error: Can't place Top/Bottom or Left/Right PLL "sclkpll:u7|altpll:altpll_component|sclkpll_altpll:auto_generated|pll1" -- I/O pin ClkIn (port type INCLK of the PLL) is assigned to a location which is not connected to port type INCLK of any PLL on the device
Here is the code for the same
sclkctrl u1 (
	.inclk(ClkIn),
	.outclk(ClktoPLL));
sclkpll u2 (
	.inclk0(ClktoPLL),
	.c0(ClkfromPLL));
Its almost like the ALTCLKCTRL block has been removed by optimization. Can you suggest any alternatives?
Gopal
    I've to run module A at half of the Clk2 frequency. I've not depicted the divider because I'm not sure which is the best way to go about
    1. Ripple clock divider
    2. Gate the Clk2 before module A (Now there will be 2 enables, one outside module A, one is already inside, I hope it will not be an issue)
    I've already tried 1 (saw some hold slack issues) and will give 2 a shot.
