CMiar
7 years agoPLL in quartus 8.0
Please how can I configure PLL in quartus version 8.0 ? I have a clock input : 50MHz and I want an output 107 MHZ
1 Reply
- Nooraini_Y_Intel
Hi CMiar,
Since you mentioned using Quartus v8.0 (for your info this software version is already obsolete), I'm assuming you are using old/mature FPGA device. At the PLL IP GUI you should be able to set the reference clk(input clock, inlclk0) value = 50Mhz and the output clock (C0) = 107Mhz. You can refer to the ALTPLL user guide from the link below for the details on how to use the PLL IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altpll.pdf
Nooraini
