PLL constraint issues
- 2 years ago
No, you didn't have to break out the PLL output clocks like that. derive_pll_clocks is fine. I was referring to the 3 extra create_clock statements you have (sclk, clk_divider...). Those are coming from internal registers, not an input port of the device, so they should be in your .sdc as create_generated_clock commands, not create_clock.
As for the failing paths, those look like they are going to Signal Tap, which is debug logic that will be eventually removed. You don't really need to meet timing there.
- GreenLantern2 years ago
Excellent! That is extremely helpful! Thank you!
As for the create_generated_clock command, could you point out to an article or suggest me how to get the template for them? How do I get their source (sclk,clock_divider2 etc.)?
Thank you!
