18 years agoPLL compilation error
Hi
I have got an error on the PLL during compilation. I have seen this error a couple of times before, but I have never figured out what the problem is. The project is a reference design which should work. It seems like the compiler cannot find the design files for the PLL. I believe that I have included all the standard folders. Does anybody know how to fix the error? Thanks Tom Warning: Using design file pll.v, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project Info: Found entity 1: pll Info: Elaborating entity "pll" for hierarchy "cycloneIII_embedded_evaluation_kit_web_server_sopc:cycloneIII_embedded_evaluation_kit_web_server_sopc_instance|pll:the_pll" Error: Node instance "the_pll" instantiates undefined entity "altpllpll" Info: Generated suppressed messages file C:/Documents and Settings/TJE/Desktop/temp download/web_server/cycloneIII_embedded_evaluation_kit_web_server.map.smsg Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 91 warnings Info: Allocated 258 megabytes of memory during processing Error: Processing ended: Wed Dec 05 12:22:11 2007 Error: Elapsed time: 00:00:52 Error: Quartus II Full Compilation was unsuccessful. 1 error, 91 warnings
